water pump replacement
Old Jan 17, 2007 | 09:37 PM
EvilDCustoms's Avatar
ok so my water pump is starting to leak now, i hear about people doing electric water pumps but i am not sure what i should do, i got the basic bolt-ons. Is it worth doing an ewp and whats the procedure for installing one of those? plus what can you use to monitor an ewp? whats are the price differences?
Old Jan 18, 2007 | 03:41 AM
2000GTP's Avatar
An electric water pump will be in the cost ballpark of a stock replacement mechanical pump. The pump can add a gain of close to 10 hp at the wheels, whether it is worth it or not is your call. There are systems on the market that make an audible noise when there is some sort of failure with the electric pump or its electrical system. As for the procedure, you have to press the impeller out of the old water pump housing and put a plug in its place and then wire the thing up. Basically, it will be a little more involved then if you were to just install a new mechanical pump.
Old Jan 18, 2007 | 11:20 AM
luckyou03's Avatar
the hardest part is the wiring. Your gonna need a 30amp fog light relay from the auto parts store and use this how-to:
http://ken.lowrance.com/projects/CSI...mp/Default.htm
*You dont have to remove the timing cover and remove the water gear*
Old Jan 18, 2007 | 11:47 AM
97WS6SCharged's Avatar
The nice thing is once you clearance the housing and install the e pump, if it ever fails it's just a matter of unplugging the electrical connection and removing a few bolts to replace it.
Old Jan 18, 2007 | 12:40 PM
Chris 96 WS6's Avatar
The question is whether the risk of inconvenience is worth 10hp. When the electric pump goes out, even if you have a "warning beep", the car's going to sit right in that spot until you can get a stock pump to put on it and/or have it towed home or to a shop.
With the stock pump, at least when it starts to fail you have time to get the car home.
Old Jan 18, 2007 | 01:31 PM
Zeetwentyfate's Avatar
EVERYONE that has a f-body or any chevy should have a backup...esp if the car is modded, modded cars will have problems. now do like i did and buy a truck and keep a trailor handy lol
Old Jan 18, 2007 | 02:24 PM
transAMdriv3r's Avatar
im just curious, does a electric water pump make getting to the opti easier or the same ? i know they are smaller but i dont know where its smaller.
Old Jan 18, 2007 | 03:11 PM
2000GTP's Avatar
It won't make a difference.
Old Jan 18, 2007 | 03:15 PM
okie dokie
Old Jan 18, 2007 | 03:17 PM
onephatZ28's Avatar
I have the CSR and I love it only $165.95 at summit
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 18, 2007 | 04:07 PM
zx1216's Avatar
I would shy away from the csr and spend a few more dollars and go with the meziere. The csr's have a design flaw in that the impeller is threded onto the motor in a fashion that the force of the water wants to unscrew the impeller. Hapened to me, the impeller spun off of the motor and lodged against the wp hosing blowing the fuse and damn near overheating my car. I was close enough to home that i could limp back thank god. Just my 2 cents...
Old Jan 18, 2007 | 06:14 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
What's the flow rate of the stock pump? How long can you realistically expect an electric pump to last? It seems like a fairly simple way to get 10 hp. Are the pumps reliable enough for daily driving?
Old Jan 18, 2007 | 09:35 PM
thanks alot guys this cleared up alot. Does anyone have a write-up on an install of a ewp on an lt1? and what tools i will need to do this, i am going to do it at the shop, i jsut want to make sure i got everything i need to get this done in a couple hours so i can drive home.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
pologreen97z
Dec 2, 2014 10:42 AM
