Water pump question
Old May 6, 2009 | 02:37 PM
  #16
user 647483's Avatar
Originally Posted by bombebomb
Going to install this soon, I was just curious on everyone's methods of blocking off the drive hole in the timing chain cover, one of the write ups I read just used a washer some black rtv and a bolt it appeared. Anyone else have different ways?
Welded in a round disc. Problem solved
You can just leave the driveshaft in there though. It doesn't hurt anything.
Old May 6, 2009 | 02:46 PM
  #17
bombebomb's Avatar
oh ok, thanks.
Old May 6, 2009 | 08:25 PM
  #18
BLKOUTZ28's Avatar
I used a freeze plug and some jb weld. Shouldnt be any problems and it's cheap to do, just give it some time to harden up. JB quick works in like 4 minutes.
Old May 7, 2009 | 08:06 AM
  #19
bombebomb's Avatar
I also thought about using JB weld on it. I might do that or I may leave the drive in there I would rather take it out.
Old May 7, 2009 | 08:48 AM
  #20
BLKOUTZ28's Avatar
You might as well take it out while you can. Those drives are a stupid idea and are prone to leak if there is any type of wear pattern on them. We all know that leaks plus opti makes for a bad day and another tear down. But if you take it out you need to take off the oil pan and timming cover so I guess it is a risk reward type of situation.
Old May 7, 2009 | 09:42 AM
  #21
RamAir95TA's Avatar
I agree with removing the water pump drive. No reason to leave it in there.
Old May 7, 2009 | 01:26 PM
  #22
bombebomb's Avatar
Water pump drive it brand new, taking off the oil pan sounds like a job lol.
Old May 7, 2009 | 06:47 PM
  #23
bw_hunter's Avatar
The water pump drive is reached by removing the intake manifold, not the oil pan.
You don't need to remove the oil pan to remove the timing cover, either. I simply cut the pan gasket on each side of the cover when removing the cover the last time. Used plenty of black RTV when re-installing and it hasn't leaked at all.
I'd leave the drive in instead of tearing things apart to take it out. There is no parasitic loss without the water pump attached and they don't really leak all that often....
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
