water pump problem
Old Aug 4, 2010 | 11:50 AM
95dude2's Avatar
water pump problem
ok i replaced my water pump because it was leaking coolant. a couple days later i noticed oil drops coming from the water pump. after 3 times of taking the water pump off, i noticed that the oil leak was coming from the cam gear that drives the water pump. i put the two 'O' rings in and it still leaks. im pretty sure that the two 'O' rings are just to prevent dirt from getting in, is there another seal that im just not seeing that i might have knicked or cut to where it leaks now? Thanks
~Chris
Old Aug 4, 2010 | 12:05 PM
Stl94LT1's Avatar
You need to replace the water pump's drive seal in the timing cover.
http://www.impalasuperstore.com/nais...TOPIC_ID=30984
Old Aug 4, 2010 | 12:26 PM
95dude2's Avatar
Oh ok thanks man
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
pologreen97z
Dec 2, 2014 10:42 AM
