Water pump noises/broken?
Old Mar 20, 2006 | 08:18 PM
Evil Eric's Avatar
Im getting a metal tapping noise, Im pretty sure its the bearing on the back of the water pump or the impeller inside it. I ued the method of using a screwdriver and putting it to my ear and I can tell its the water pump or the water pump drive gear. This common before they fail?
already checked the valve lash, no loose rockers, and no header leaks. No its not a spun bearing either.
Old Mar 20, 2006 | 09:22 PM
Evil Eric's Avatar
Re: Water pump noises/broken?
Anyone ever heard of the bearing failing in the drive gear assembly?
Old Mar 21, 2006 | 01:03 AM
Evil Eric's Avatar
t t t
Old Mar 23, 2006 | 05:08 AM
Guest47904's Avatar
Guest
The water pump on my stocker had 130K+ on it. Never made a sound. When I removed it to do the opti I saw the bearing had actually lost some *****. Chances are yours is the same.
I hate when they loose some *****
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
