Water pump issue
Old Feb 8, 2009 | 01:22 PM
Drew24's Avatar
Water pump issue
I got a new water pump and for some odd reason there is a gear in the back and also there is another gear in the block where it mounts too they are both males and not females they dont plug into one another im not sure if the old water pumpes gear fell off and is stuck in the block or they gave me the wrong pump. Did they change anything with the water pumps from 93 to 97? Any suggestions on what to do.
Old Feb 8, 2009 | 01:34 PM
caldercay's Avatar
Yep ... there's a coupler that mates the two males splined shafts.
If you've taken the pump off, then the coupler must have fallen off.
Old Feb 8, 2009 | 01:36 PM
Drew24's Avatar
where could i get another one
Last edited by Injuneer; Feb 8, 2009 at 02:24 PM. Reason: Do not override the language filter
Old Feb 8, 2009 | 01:43 PM
caldercay's Avatar
Chevy (GM) dealership.
But if I were you, just look around where it might have fallen off.
Old Feb 8, 2009 | 01:45 PM
caldercay's Avatar
http://www.corvettetraderonline.com/...productid=1206
Old Feb 8, 2009 | 01:49 PM
Drew24's Avatar
thanks i ll give that a try i think i left it on the core charge that i turned in
Old Feb 8, 2009 | 01:53 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I can't believe the coupler is that expensive. Assuming the guy lost his, I would recommend shopping around.
Old Feb 8, 2009 | 02:32 PM
sbs's Avatar
sbs
$85!
Never buy anything from a corvette specialist unless it is the last source on Earth.
GM list is $45, which is still a lot.
Old Feb 8, 2009 | 02:36 PM
brianswimmer23's Avatar
go to the junk yard and get you one for next to nothing.
Old Feb 8, 2009 | 03:23 PM
caldercay's Avatar
Understood ... I wasn't suggesting necessarily that they buy
from this source - it was more to show them what the coupler
looks like, so they know what they're looking for
I certainly, along with any other sane person, wouldnt pay that much!
Old Feb 8, 2009 | 09:16 PM
http://shbox.com/ci/water_pump.jpg
Old Feb 8, 2009 | 09:51 PM
Style's Avatar
$27.70 plus shipping on gm parts direct
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
