water pump install ??????? need help
Old Jun 15, 2004 | 09:59 PM
ericz28w's Avatar
i got all of the bolts out except for the bottom right bolt, then i took that bolt out and collent came rushing out of the bolt hole, and not out of any of the other holes, so it got me wondering if something could be wrong. the other bolts just had oily goopy residue on them??
fill me in
Eric
Old Jun 15, 2004 | 10:49 PM
Not to worry. Your car is just probably situated to where that is the lowest point and most of the coolant is coming out that hole. You can check the other holes for obstructions after you get the pump out.
Old Jun 15, 2004 | 10:57 PM
CeeBee94Z's Avatar
Yea, don't worry about it, when I installed mine coolant came out both bottom bolts, it will always come out at least one unless you pull the drain plugs on the block to drain whats in the block itself.....
Old Jun 30, 2004 | 06:00 AM
island_boy78's Avatar
guys do you have pics of the install? any tips for me as I will have to do so tonight... and where is the drain plug for the block? don't want to waste the coolant.. as most of it is brand new.. only put in a week ago.
Old Jun 30, 2004 | 06:04 AM
Sleeper_Z's Avatar
Just get a bucket or a pan and put under the car if you are worried about losing coolent. If you lose little it will be no big deal. Just top it off with water and bleed the air out of the system and your back in business.
Old Jun 30, 2004 | 06:09 AM
thanks for the quick reply.. I just notice that this was the Lt1 thread.. I have a LS1.. do you know if it is the samething?
Old Jun 30, 2004 | 06:12 AM
Sleeper_Z's Avatar
Im not sure on the LS1 stuff. Ive done some minor work on them but never tore into the motor that far. Hop over to the LS1 forum and ask those guys or go to LS1tech.com and post there to get some solid info. Hope that helps.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
