Water Pump Install Help...Quick
Old Nov 26, 2003 | 10:15 AM
BLB 97 Formula's Avatar
Trying to change my water pump right now but have a question. I drained all the coolant from the radiator but it was only about 1.5 gallons of it, where is the rest of the coolant at??? I thought the coolant capacity was around 4 gallons.
Help me please...how do I make sure to get all the coolant out....where exactly are the block drain plugs?? Thanks a lot.
Old Nov 26, 2003 | 10:17 AM
quicksilver97ta's Avatar
The remainder of the fluid is in the block but dont worry about it, its not neccessary to drain all of out for a waterpump install.
Old Nov 26, 2003 | 10:20 AM
klbjoc's Avatar
If you do want to drain the block, there is a plug above the oil pan on the drivers side and there is the knock sensor on the pass side above the oil pan.
Old Nov 26, 2003 | 10:48 AM
How do you guys get the old radiator hoses off of the pump? Mine are stuck on there so tight, is there some secret to it??
Old Nov 26, 2003 | 10:54 AM
klbjoc's Avatar
you just need to twist and pull. I would check them to see what kind of condition they are in. If they look like they need to be replaced, take a razor blade or a box knife and just cut a slit in them where they connect to the pump and slide them off and get new hoses. Now would be the best time to replace them.
Old Nov 26, 2003 | 10:55 AM
PoorMan's Avatar
That usely means they are swollen on because they are old. Slice them with a box cutter and replace them.
Jeff D.
Old Nov 26, 2003 | 12:39 PM
Can someone tell me how I get the AIR bracket off. I have all the bolts out of it and it seems to "wiggle" around but I can't pull it off, something is holding it back or catching on it. ANy ideas???
Old Nov 26, 2003 | 01:33 PM
I've now got the pump stuck on one of the dowel pins and can't get it off. Anybody have any suggestions on how to get it off the dowel pin. Thanks!!
Old Nov 26, 2003 | 01:39 PM
joeSS97's Avatar
Put a screwdriver between the pump and block and pry it off.
Old Nov 26, 2003 | 01:55 PM
Where do i put the screw driver, there isn't a place to put it?
Old Nov 26, 2003 | 02:27 PM
joeSS97's Avatar
Ok,pry on any part of the pump that you can.Try tapping it with a hammer also.
Old Nov 26, 2003 | 03:42 PM
RamAir95TA's Avatar
You're missing one bolt. The pump is held on by 6 bolts, and one doubles as the AIR pump stud. That's probably why you can't get the pump off of the block, and the AIR pump bracket removed.
Old Nov 26, 2003 | 04:17 PM
Got the pump finally off and quite for the day. Is there some secret to getting the old coolant temp sensor out of the old pump and into the new? ALso, how important is it to get rid of ALL the old gasket material. Thanks
Old Nov 26, 2003 | 04:20 PM
klbjoc's Avatar
It is very important that both surfaces are completly clean and dry.
Old Nov 26, 2003 | 04:36 PM
tend2609's Avatar
umm, you can reuse the temp sensor but i would just run and and get a new one, y not, they are cheap and 1 less thing to worry about, i usally replace many parts when i do stuff like that on my car, if in doubt get a new one.
