Water pump? help asap
Old Aug 30, 2004 | 04:22 PM
78sixbanger's Avatar
Ok, i just got home , parked my car, and antifreeze started spilling out the bottom of my car. Car didnt get hot, and wasnt doing it when i was driving. I got under it and it looked to be coming from the water pump. Im not 100% sure though. Pulled off the intke elbow and looked to be some residue under the throttle body on top of the water pump. It was coming down in a stream. Looked like it spilled 1/2 a gallon of antifree. Any ideas.
Old Aug 30, 2004 | 04:46 PM
red96taA4's Avatar
Re: Water pump? help asap
is this the first time youve noticed it happening? when a water pump starts wearing out, it starts to leak from the weap hole on the bottom of it. you say it spilled 1/2 gallon, thats alot to come out of that little hole. it doesnt sound like the WP, especially since you said it was on top of it and under the throttle body. check the hoses. they might only leak when the car heats up. i had a tear in one and it would only do it after i let the car heat up, then it would spray like a garden hose.
Old Aug 30, 2004 | 04:51 PM
not sure if was antifreeze on the top or not. See thats the wierd thing, it was a little stream bout a cm in diameter. and it ws comin own the back of the wp, by where the little plastic clamp to keep the wires for the sensor away from everything is on the wp. It was comin right over that
Old Sep 3, 2004 | 02:30 AM
Klevs23's Avatar
Check all the water pump bolts mine was leaking like a real small stream but when hot leaked alot and i tightened all the bolts that hold the water pump on and it does not leak anymore
Old Sep 3, 2004 | 02:51 AM
S8ER95Z's Avatar
Check your Throttle Body area for a hose off...it would flow down that way..might make it look like the WP?? Otherwise the WP just seeps..usually really small amounts.
Old Sep 3, 2004 | 05:38 AM
red96taA4's Avatar
i didnt think about the throttle body. have you done a tb bypass? if so, then no need to look there. if you havent, theres a line going into the throttle body, and one coming out on the opposite side. gm thought we would be driving around in arctic conditions all the time, and didnt want the throttle body blades to freeze up on us, so they ran some coolant through the TB. its worth checking out.
Old Sep 3, 2004 | 09:50 AM
Im pretty sure the origanal owner did the bypass. The one metal tube comein from the bottom pass side of the tb as nothin goin t it. And te one on the driver s capped off. Anyway, I replaced the wp. And the problems stoped. So that was it. Thanks so much for all the help though guys. Just shows me again why I love these boards so much.
Old Sep 3, 2004 | 12:04 PM
red96taA4's Avatar
well, im glad to hear everything worked out for you. and yes, it sounds like the tb bypass is done already for you.
Old Sep 3, 2004 | 01:53 PM
Thanks again guys, really appriciate it
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
