Water Pump Gear Sleeve Question!
Old Aug 7, 2004 | 01:19 PM
Rich_z28's Avatar
Question Water Pump Gear Sleeve Question!
Is there a certain way this has to go on? It looks like it's the same on both ends inside. But the out side has a ring at one of the ends. I took it off before I noticed this and was wondering which end the ring has to go on? The block or water pump? Thanks.
Old Aug 7, 2004 | 01:34 PM
RamAir95TA's Avatar
Re: Water Pump Gear Sleeve Question!
I don't think it really matters, but when I took mine off, the "ring" faced the block.
Old Aug 7, 2004 | 03:12 PM
Yep
Old Aug 7, 2004 | 03:26 PM
Lyle A's Avatar
Would it matter if it was backwards? 50/50 chance if you don't pay attention.
Old Aug 7, 2004 | 03:51 PM
sbs's Avatar
sbs
It matters enough that the instructions with my replacement water pump said which way to orient it. Whether it will really hurt anything I don't know.
Old Aug 7, 2004 | 03:58 PM
Lyle A's Avatar
Well, I guilty of not taking note of that part of it. Might be right, might be wrong. If I pull it off to check, it will be right. If I leave it, it will be wrong. Right? Oh well. No worries.
Old Aug 8, 2004 | 01:45 AM
Rich_z28's Avatar
Thanks guys.
Old Aug 8, 2004 | 04:47 PM
arnie's Avatar
Is there a groove near one end of the coupling/sleeve? If there is, the end with the groove, will go toward the engine block.
Old Aug 8, 2004 | 04:53 PM
Rich_z28's Avatar
The groove is what I was talking about. Thanks for the help.
Old Aug 8, 2004 | 04:59 PM
arnie's Avatar
Look REAL close at the I.D. (inside diameter) at each end, and see if you can tell any difference.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
