water pump gasket removal (did search)
Old Apr 2, 2005 | 05:19 PM
pillagenburn's Avatar
OK, i have teh water pump off and everything - i seem to have removed most all the gasket from the block but on the water pump itself there is gasket material left and its REALLY in there. I've tried using a razor blade to get it off, but it almost seems as if i'm taking aluminum shards off of the water pump itself. Will it be OK if i just clean it up as best i can and just use the felpro gasket/RTV?
Or does the surface need to be absolutely completely stripped of gasket?
thanks!
Old Apr 2, 2005 | 05:27 PM
CoUnTryMuZiCZ28's Avatar
Re: water pump gasket removal (did search)
I would completly strip the surface.. They make sprays that work if you let them soak. or you can go to home depot and get a scuffing pad or w/e.. damn i forgot what its called.. it goes on a dremel and wont harm the surface but will eat through the gasket.. looks like a honey comb/bees nest type thing. you can also just lightly sand the surface..
Old Apr 2, 2005 | 06:57 PM
1 Nasty Bird's Avatar
The spray has worked VERY well on the stock water pump gasket that was on my other LT1. SPray soak spray repeat till perfectly clear. Also a thin layer of RTV neverr hurt anything.
Old Apr 21, 2005 | 09:13 AM
tardy007's Avatar
Someone suggested oven cleaner spray as well. I have NO idea if that works. Anyone tried that???
I am looking as well. I've spent hours on this, did they super glue these things on at the factory?
Any other suggestions?
Old Apr 21, 2005 | 09:32 AM
slashz28's Avatar
Gasket remover, as the others abve said, + a razor, itll take a bit of time, but will be much easier. hth
Old Apr 21, 2005 | 10:52 AM
ajschult's Avatar
If you have access to some air tools, use the one that is essentially a wire brush. Worked well for me.
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
