Water pump drive shaft q...
Old Sep 3, 2008 | 08:57 AM
MikeNice's Avatar
Hey guys, so I have a CSR EWP on my 94 Z28. I wanted to upgrade to a double roller timing set, but since I JUST bought a non vented opti, I decided to stick with the stock timing set. Anyways, my question is, can i still remove the water pump drive gear? I see no need for it and want it gone, as long as I can do that with the stock timing set. Let me know, thanks
Old Sep 3, 2008 | 09:00 AM
Yes, you can remove the gear.
Old Sep 3, 2008 | 09:02 AM
MikeNice's Avatar
Can i take it out without taking the intake man off? Can I work it out easily? I know i can leave it in, but I had a timing chain failure and the sprocket is chipped anyways, so Id like it out. And a freeze plug will fit in the timing cover right?
Old Sep 3, 2008 | 10:59 AM
MikeNice's Avatar
Nevermind, got it out, thanks shoebox!
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
