water pump drive shaft
Old Feb 19, 2006 | 07:44 PM
194bird's Avatar
what is the best way to get the water pump shaft and bearing assembly out of the block and do you have to remove the intake to do it
Old Feb 19, 2006 | 07:47 PM
Alex94TAGT's Avatar
Re: water pump drive shaft
Yes, the easiest way is to remove the intake manifold, and tap it out from behind.
However, I've removed mine from the front with a large pry-bar. It can be done, but it's somewhat difficult to 'grab' it well enough to get any force on it.
Old Feb 19, 2006 | 08:01 PM
194bird's Avatar
thanks i will try it this weekend without removing the intake so i want have to buy new gaskets again in a couple of weeks when i do my cam trying to get some good times with just bolt ons
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
