water pump drive gear
Old Dec 13, 2004 | 12:20 AM
Daniel6718's Avatar
does anyone know or been inside the timing chain area and know how to remove the waterpump drive gear??? its on top behind the cam gear...because somehow i jammed and stripped the waterpump drive gear and the cam gear was damaged adn now the wpdg is stuck and idk if i have to pull the inatake manifold to get to it or not...thanks for the replies tonite i need them by tomaro bc thats when im supoposed to go work on it...thanks
Daniel
Old Dec 13, 2004 | 12:33 AM
Z95m6's Avatar
Re: water pump drive gear
You just take off the timing cover and cam gear. Then remove the 2 bolts for the water pump drive gear and it mostly likely will need to be hammered from the back side out. You maybe able to leave the intake on and some how rip it out the front but i would probably plan on pulling the intake.
Old Dec 13, 2004 | 07:45 AM
Ken95Z28's Avatar
Water Pump Shaft Removal
When you get to this page click on the left where is say's Water Pump Shaft Removal, basically you pri it out, there is no way of getteing to the back side of it unless you remove the intake.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
