Water pump bolts, reuse or replace? Part #?
Old Aug 25, 2010 | 01:47 AM
Rob94hawk's Avatar
This will be the 2nd time I've used the origional stock waterpump bolts. It's probably safer to just replace them. They look like hell anyway.
Part #? Thanx
Old Aug 25, 2010 | 02:52 AM
RamAir95TA's Avatar
Part #? Thanx
They are a pretty common size, readily available. 2 bolts are 3/8"-16x2" and the other 4 are 3/8"-16x4".
Old Aug 25, 2010 | 03:04 AM
Rob94hawk's Avatar
Good so I guess I can go to my local ACE Hardware store and pick them up. Thanx.
Old Aug 25, 2010 | 12:07 PM
PWR SHFT's Avatar
Really unnecessary. Waterpumps are not stressed parts like a head bolt, cam bolt, reciprocating assembly fasteners, etc. that can wear out or fail after repeated torquing. Unless the bolts are damaged or you are changing them for asthetics, i would leave them alone and save your money.
Old Aug 25, 2010 | 12:39 PM
bw_hunter's Avatar
They usually get gunked up living in the water jacket like they do....I'd replace them as they don't cost much. Be sure to clean the bolt holes carefully using a thread chaser as sealer often builds up there.
Old Aug 25, 2010 | 12:58 PM
GRIDERMAN87's Avatar
You should be able to find them at about any hardware store
Old Aug 25, 2010 | 01:08 PM
sherwinZ28's Avatar
I've replaced my waterpump/opti 4 times now and reused the same bolts...however I've always cleaned the bolts and bolt holes with degreaser and brush. Seems fine to me. No need to waste money, unless you see something wrong with the bolts.
Old Aug 25, 2010 | 03:51 PM
wrd1972's Avatar
Old Aug 25, 2010 | 06:46 PM
Rob94hawk's Avatar
The bolts are just gunked up with crap. If I can't get them cleaned up then I'll just replace them.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
