water Pump ?
Old Nov 16, 2008 | 08:21 PM
football4life's Avatar
water Pump ?
Ok so I just started my freshly rebuilt engine this weekend. The water pump leaks through the weep hole (pretty good stream) Until the engine gets warm then it stops leaking. I know that when the weep hole leaks that means that the pump is gonna go but Im wondering if maybe I didn't bleed it right or something because it keeps the car cool and only leaks for a couple mins. does anybody have any ideas, should I just replace the pump and call it a day, or try to figure out the problem.
Thanks Josh
O, its the stock pump with 80,000 miles on it.
Old Nov 16, 2008 | 08:52 PM
SnakeSkinner28's Avatar
Easy call man, replace it. There cheap and easy and once there off have a high tendency to leak. They generally start to need replacing around 100kish anyway...also id replace your thermostat at the same time because its only a matter of time before that fails as well and youd be stranded. There like $20 from any aftermarket parts store and id recommend staying with the 180 thermo and not going with the 160 despite some people will say you get more power...check with the tuners like PCMforless or MadZ28, I know Bryan at PCM advocates the 180.
Old Nov 16, 2008 | 09:28 PM
A new GM pump comes with a thermostat installed.
Old Nov 16, 2008 | 09:30 PM
Stl94LT1's Avatar
The pump is bad. Replace it before it takes out you opti.
Old Nov 16, 2008 | 10:22 PM
yea and if you have the money you may as well replace the opti spark. As far as I know you dont have to change plugs and wires just because your changing the opti, but since the pump is already off, and optis usually start to have issues about 100K as well, id replace it too.
Old Nov 16, 2008 | 10:49 PM
Green96Z's Avatar
Both of my Autozone pumps did not come with a thermostat. Just a heads up.
Old Nov 17, 2008 | 08:13 AM
Well then, its a pretty clear choice. Does anybody know where to buy a good pump for a decent price?
Old Nov 17, 2008 | 09:10 AM
derrickgott007's Avatar
O'reilly's has a great price for water pumps. My new waterpump for my 97 LT1 cost only like $70 bucks...that was new....rebuilt was only like $45 or so and their rebuilts are pretty good....well waterpumps anyways...opti's no.....lol
The pump I got has a lifetime warrenty and it came with all the gaskets and shaft bearings etc..... very nice and almost had a polished appearance to it. It really dressed up the black block in my car.
Old Nov 17, 2008 | 10:41 AM
bigbirdta94's Avatar
i wouldnt go with anything aftermarket...ive had two of the a/m pumps fail on me and they did what yours is doing. go with the factory one.... you maybe spending a lil more but you can basically garauntee that it's not going to leak on you
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
