water pump?
Old Apr 4, 2007 | 02:31 PM
nocturnalLT1's Avatar
water pump?
need a water pump and thinking about going electric while im at it. ANY RECOMMENDATIONS?
Old Apr 4, 2007 | 02:47 PM
2000GTP's Avatar
CSR and Meziere are the two popular choices.
Old Apr 4, 2007 | 03:16 PM
zx1216's Avatar
spend a little extra and get a meziere, the csr damn near left me stranded with an overheated car, the impeller spun off the motor shaft and jamed the pump which blew the fuse. long story short the threads on the shaft are threaded in the wrong direction...
Old Apr 4, 2007 | 03:32 PM
wheres the best place to get them from, Summit? and with those i just reuse the stock housing correct? does it matter what the flow is.
Old Apr 4, 2007 | 03:40 PM
colossus's Avatar
i got mine off of summit, and yea it reuses the stock housing, just have to cut out a notch in the fan shroud to fit the pump
Old Apr 4, 2007 | 03:45 PM
ibanez6rg's Avatar
No complaints about the CSR here. IMO, it doesn't matter which one you go with - it will either be a hit or miss with either one.
Old Apr 4, 2007 | 03:52 PM
zx1216's Avatar
The only reason i don't like the csr is that the impeller was threaded on to the motor in a fashion that the force from the impeller rotating through the water unscrews the impeller, all that is holding it from spining off is locktight. If they would have threaded the shaft in the reverse direction there would be no issues...just my $.02
Old Apr 4, 2007 | 04:01 PM
any major differences between the 55gpm and 43 gpm besides the "GPM"? and will i need the suggested "wiring relay kit"?
Old Apr 4, 2007 | 04:27 PM
sworaz
Guest
Posts: n/a
more Gallons per min. I really like the miezere. The cheapest I found it was on Summit. Good luck
Old Apr 4, 2007 | 04:49 PM
Ironxcross's Avatar
dont bother with the electronic one if you drive it everyday, otherwise, go for it.
Old Apr 4, 2007 | 07:53 PM
colossus's Avatar
yea you'll need to get the relay kit
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
