Water pump?
Old May 30, 2006 | 05:39 PM
96Z28fella's Avatar
Water pump?
I am in need of a new water pump. I have a 96 LT1 camaro, anybody have any preference on which pump to get. I have the choice of a stock replacement, CSR performance electric water pump, or a Meziere electric water pump? anyone have the electric water pumps and any pro an cons??..thanks
Old May 30, 2006 | 05:46 PM
user 647483's Avatar
Re: Water pump?
I like the Meziere EWP, it's been a popular install for a few years now.
I think it's a great investment ($199 + a few hours work)
http://www.ws6.com/kelley-wp.htm
PRO : Helps reduce HP loss, (dynoed by several people at +5-10rwhp)
Runs cooler (I've seen a few people disagree on that one)
CON : Does not last as long as a mechanical pump.
Either way, when the pump fails (mechanical or otherwise), your engine will get hot and you will need to replace the pump. If it leaks (I don't see the EWP being any more likely to do so than a mechanical pump) you run the risk of frying the optispark ("distributor").
Old May 30, 2006 | 08:52 PM
Javier97Z28's Avatar
Moderator
Re: Water pump?
CSR's been fine by me
Old May 30, 2006 | 09:13 PM
I burn rice too's Avatar
Re: Water pump?
I've always had a CSR on my cars. I've never had a problem with them.
One of the best advantages, is that if it does go bad, your not going to have coolant dripping allover your Opti. Sure the temp will rise but that's why they put temp gauges on these cars.
Old May 30, 2006 | 09:35 PM
Pokey's Avatar
Re: Water pump?
Went to a CSR about a month ago. Working OK so far.
Averaged just under 19k on the last 3 mech pumps so decided
an electric couldn't be worse! Hope I didn't just jinx it!
Reads about 197-201 city and highway on my scanner. (180 stat)
'94 M6 mostly stock (except for ewp)
Old May 31, 2006 | 07:26 AM
96Z28fella's Avatar
Re: Water pump?
thanks guys..i appreciate your input..im gonna have to go with a electric water pump..ill let you know how it goes..
Old Oct 16, 2008 | 06:32 PM
z275plus's Avatar
I have had 3 ewp's in the past 3 years, I have had enough of this, going back to stock.
Old Oct 16, 2008 | 09:00 PM
Don 97 SS's Avatar
You sure had a bad batch of mechanical pumps.
Old Oct 16, 2008 | 09:19 PM
caldercay's Avatar
Ok, so maybe the electric might not last as long.
However, when the electric goes out and you need to
replace it, it will take about 20 minutes to change out.
I've replaced the mechanical a couple of times and
switched to the Meziere. I *guarantee* that I would
rather change out the Meziere rather than the stock,
two to one.
I calculated the "hours of operation" I should get out
of the Meziere, and it's close to 3 years.
Old Oct 16, 2008 | 09:31 PM
Green96Z's Avatar
FWIW, I've always stuck with stock. But then I also have a lifetime warranty. Plus I like the idea of never having to worry about if my water pump is actually working (I know there are ways to wire up warning lights, but I just like the peace of mind).
Old Oct 16, 2008 | 09:32 PM
600hplt1sm's Avatar
Check out this link http://www.thunderracing.com/catalog...p&vid=4&pcid=5
This is the Meziere heavy duty electric pump for 236.00. This is the one I bought and its been great. The standard Meziere EWP is rated @ 42GPM. The HD is rated @ 50 GPM.
Old Oct 17, 2008 | 03:24 AM
henryz28's Avatar
I have had my csr for over 2 years and it works great. Car never gets over 1/4 on the temp gage.
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
