water in oil - gasket and heads fine?
It started with white smoke and coolant loss, so I had it checked and they said blown gasket or cracked heads. I take it home and take the valve cover off one side, sure enough it's milky as hell. So I go through and remove each head, gaskets look fine on both sides. So I send the heads to my engine builders for testing, they just called me today and told me the heads, and valve seats looked fine, but some of my valves were quite worn and needed replaced.
So what now? If not heads or gaskets then what? I told him I had water in the oil so he said he'd keep looking at the heads, but what would cause such wear on the valves at only 12k miles? They were manely steel valves I think. Oh, and also, the pistions were pretty built up with carbon.
There should have been at least one clean cylinder with the coolant loss... if so, check for a crack in the cylinder.
If all of the cylinders looked ok, then maybe you had a seal go on the back of the heads on the crossover steam pipe. It is possible that coolant would have dripped from that area and onto the exhaust.
If you had smoke from the tail pipe, then you either have a concern with a cracked block, cracked heads, or head gasket... and it seems you have ruled out 2 of the 3.
Another possibility for coolant loss would be through the head bolts/studs, but that wouldn't make white smoke / steam.
You can't always tell just by looking. Have you taken a straight edge to the block yet?? Also you could have been leaking water into the valve cover from cracks, usually around the spring seats. Maybe that's why the valves are worn.
Well it turns out that when he called me they hadn't even magnaflux or pressure tested it yet. So I'm still waiting to hear back. And he says the valves were worn from the coolant in the oil, washing away the oil on the valve. Also, I mentioned in another thread that when I took the intake manifold off, much of the bolts didn't need a wrench to come off, I took them off with my fingers. Is it possible that that could have caused water in the oil? The guy I talked to said that was a possibility when I told him, but he may not know the LT1 off hand.
Water in the oil can be a sign of a cracked block as well as problems with head gaskets or the heads themselves. If you've lost coolant, found milky oil and the pistons weren't 'steam-cleaned' I'll bet the block is cracked.
Sorry...
Sorry...
