Water leaking from cutout
Old Feb 5, 2008 | 05:40 PM
ssbowtie1's Avatar
Is this normal? The other day I started my car and was checking for exhaust leaks and noticed the cutout was dripping slowly. I touched the small puddle under it and it looked/felt/smelled like pure water, with no coolant. Is it normal for there to be that much condensation that water drips out the cutout? The location of the cutout is right before the rear axle.
Old Feb 5, 2008 | 05:47 PM
2000GTP's Avatar
It is a normal byproduct of your exhaust, nothing to worry about.
Old Feb 5, 2008 | 09:47 PM
rexcellent's Avatar
It's nothing but condensation. After your exhaust pipe reaches the right temperature it will stop.
Follow around a few cars on a cold morning and you will see a lot of them "steaming" from the tailpipes.
Old Feb 6, 2008 | 01:49 AM
GreasyB's Avatar
If you are worried about it just check your coolant level often. But I am guessing its nothing to worry about.
Old Feb 6, 2008 | 07:22 AM
JooneJune's Avatar
A good running FI motor will produce a little condensation, that normally burns off within 5-10 minutes...
Old Feb 6, 2008 | 11:51 AM
ALL motors produce condensation. When you burn gasoline, one of the main products of combustion is water. Has nothing to do with it being "a good running FI engine". The cutout blanking plate is going to be the coldest part of the exhaust, and water will build up there in cold conditions.
Old Feb 6, 2008 | 12:36 PM
white97T/A's Avatar
Pay attention to some mustangs, they always have water pouring out of the exhaust pipes.
May 21, 2015 01:04 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
