water in ecm
Old Aug 27, 2007 | 03:20 PM
Thomas2244's Avatar
water in ecm
Does anyone have a picture of the ecm cover for a 97 LT1?
Old Aug 27, 2007 | 03:45 PM
The Engineer's Avatar
Are you referring to the PCM (Powertrain Control Module). Also, how does the thread title relate?
WD
Old Aug 27, 2007 | 05:12 PM
Thomas2244's Avatar
reply
water got in the ecm from dripping from the cowl. wondering if there is supposed to be a cover on the ecm, as the plugs are exposed. o-rings look to be in good condition on the connectors.
Old Aug 27, 2007 | 05:18 PM
pizzi-man's Avatar
Don't know about the 97 but the 95 has breather holes on the knock module cover. other than that it's pretty much water tight.
Old Aug 27, 2007 | 05:20 PM
There is no cover on the PCM. There is a screwed cover plate with a rubber gasket for the knock module:
Courtesy of Shoebox:
http://shbox.com/1/lt4km.jpg
Old Aug 27, 2007 | 05:26 PM
mdacton's Avatar
the plastic cover/hold down for it...I can see how that would sheild water from the cowl area, don't a pic of one.....sorry
Old Aug 27, 2007 | 05:32 PM
Thomas2244's Avatar
that is exactly what i am talking about. we got a lot of rain the other night and i just need the cover to divert water, not make it air tight. water pouring off the cowl area onto the plugs and eventually you're gonna get water in it.
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
tdigger9899
Sep 7, 2015 10:56 AM
