Water in a cylinder do I have to rebuild?
Old Jun 11, 2009 | 11:46 PM
lc94z's Avatar
As where I thought it was my flywheel that broke off two starter motors, my mechanic says that he found water in the far back passenger side cylinder. Is my only option to rebuild this engine? It ran fine to work that day with no loud booms or sounds or anything. Also I did notice that it was starting slower and slower. Someone told me that I can just have the heads worked on and have the cylinder dried out and oiled up and I will be fine. Does anyone know if there is any truth to this???? This car is sooooo clean...i just can't afford to drop a new engine in it.
Old Jun 11, 2009 | 11:55 PM
Depends where the water/coolant came from. Could have come from a leaky head gasket, or a crack in the head, or a crack in the cylinder wall/water jacket.
Old Jun 11, 2009 | 11:59 PM
lc94z's Avatar
well the last thing that I worked on on the car was I personally changed the intake manifold and it was running fine. I noticed that if I would drive for a while and would come to stops, the water indicator light for the radiator would come on and the car would start over heating unless I put the brake and the gas on to keep the rpms up but I NEVER let it redline as far as overheating.
Old Jun 12, 2009 | 10:13 AM
lr383's Avatar
Pull the head off to see if it is a head gasket then you can go from there water in the cylinder is no good, have the head check by your machine shop.
Old Jun 13, 2009 | 07:09 AM
Wooshie's Avatar
mine did this also. i had blown out the rtv seal on the back of the intake. it was bleeding to death as fast as i could put oil in. grab a flexible mirror and look @ the back of your intake. i broke 4 starters befor i fixed mine. pull all the plugs, roll the motor BACKWARDS by hand to get the fluid out of the cylinders. replace plugs start car for about a 1-2 minutes. STOP drain all oil and change filter, run the car to operating temperature. STOP change oil and filter again. now go play. mine hydro locked twice from a bad intake gasket not a head gasket after my cam swap. this is how i fixed mine. you have to get all the water/coolant out of the oil or you will spin a bearing. hope this helps.
Old Jun 13, 2009 | 11:54 AM
lc94z's Avatar
Thanks wooshie! that sounds doable I will post once I have tried this.
Old Jun 13, 2009 | 01:17 PM
The LT1 intake manifold is "dry". There are no water passages at the intake gasket. How would leaking RTV or a leaking intake gasket put water into a cylinder? Or am I missing something here?
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
