water/coolant leaking through this hose
Old Jan 12, 2015 | 04:27 PM
94Z28LS1toLT1's Avatar
Hey guys that water hose that connects to the water pump on the drivers side below the upper radiator hose i believe its half rubber and half metal and runs all the way to the back of something lol. I see coolant/water leaking through the metal part,very slow leak. But was wondering how can i get that hose fixed, because i think it runs all the way to the oil adapter. thank u guys
Old Jan 13, 2015 | 07:10 AM
Re: water/coolant leaking through this hose
What you are calling the oil adapter is the oil cooler. Many people delete it because they don't see a need for it (GM only installed it through 95), or because they feel it can plug up and hurt oil circulation. I've had it functional for 20+ years with no problems.
You may be able to find the coolant line from someone who deleted the cooler. Might want to try posting on "Parts Wanted".
If you delete it, you would use the "oil cooler bypass hose" shown in this diagram:
http://shbox.com/1/93-94_hoses.jpg
This is the oil cooler plumbing diagram:
http://shbox.com/1/oil_cooler.jpg
Old Jan 13, 2015 | 05:01 PM
my bust Fred yea the oil cooler,I couldn't remember that name to that part,checked it again and theres a small crack in the metal part of that hose.
Old Jan 14, 2015 | 06:54 AM
As a temp fix, wrap a split piece of rubber hose around the area of the crack in the pipe, and put a band clamp over the area to hold the hose tight against the crack.
Old Jan 14, 2015 | 09:48 PM
Thank you buddy,but i actually got one from a guys selling parts from craigslist from a 95 LT1 and he had that part got it for 10 dollars in pretty good shape.
Old Jan 15, 2015 | 09:22 AM
95s were different from 93-94s. So, unless you got the whole thing, it might not work.
Old Jan 15, 2015 | 04:35 PM
Dang.... good catch. This is the 94:
Old Jan 15, 2015 | 07:18 PM
Hey guys my mistake I got it from a 94, i called a different guy before that asking for that hose he was parting out a 95 but didnt have that hose thank god. But did get that hose from a 94 all clear
Magenta_Hearts
Mar 29, 2017 08:54 PM
Scorch1
Jun 30, 2015 11:24 PM
beltrunner
Apr 15, 2015 01:10 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
pologreen97z
Dec 2, 2014 10:42 AM
