Washed my K&N air filter with Simple Green. Bad Idea?
I had no washing solution that came with the K&N filter anymore and the filter was pretty dirty after 6 years. So I used simple green solution. Came out pretty clean and I rinsed it pretty thouroughly. I didin't see any instructions on not using anything else other than their cleaning solution.
So you think it's ok to oil back up?
Re: Washed my K&N air filter with Simple Green. Bad Idea?
Simple Green is not harsh at all. I would rather you use the supplied kit, only since its for that type of filter. As long as you use the oil to re oil it, you should be more than fine.
Originally Posted by 97FormulaWS-6
that's actually what I use.... simple green and a hose.. but 6 years
I do mine once a season; about every 7K miles...
I do mine once a season; about every 7K miles...Thread
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
