Warning to Long tube users
Old Jul 15, 2003 | 04:20 PM
ZDriver96's Avatar
I went out and looked more into my cruise control problem and found that my Long tube header on the drivers side sits right against my cruise control cable that connects the Throttle body to the the cruise control module.
It had burned through the rubber insulation and burnt some of the metal cable of on the inside too.
Im still unsure y my cruise control doesnt work because its just a cable right? even if its burnt it still should work..
I think....
Well just to let u know what i found.
Old Jul 15, 2003 | 04:30 PM
Izod's Avatar
probably fried the innards of the wire. as in its not strong enough to carry a full signal anymore - also could easily be a relay/fuse somewhere.
Old Jul 15, 2003 | 04:43 PM
IrocManiac's Avatar
Thats what I was beginning to think.
Old Jul 15, 2003 | 05:41 PM
ZDriver96's Avatar
I dont know of any relays that the cruise uses...
Only fuse is in the engine bays fuse box right (its fine)
Well regardless im replacing it.. Most likey thats the problem.
Old Jul 15, 2003 | 06:48 PM
95 WHITE TRANS's Avatar
ZDRIVER96 out of curiosity are your headers coated.
THANKS
NICK
Old Jul 15, 2003 | 07:27 PM
revtime's Avatar
Coated headers will help but that cable needs to be put behind the shield that protects the brake lines.
Easy to do and it will solve your problem.
Old Jul 16, 2003 | 08:58 AM
ZDriver96's Avatar
yeah they are jet hot coated... and yeah I should have seen it when i installed it, and put the cable behind the heat shield.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
