warning lights
warning lights
i just instaled a water pump and an opti and My ses and airbag lights keep turning on and off, the car still runs fine with these on im just wondering whats causing these to come on im mostly worried about the airbag light i dont want it to explode in my face or something, also i think i know why the ses light is on but i need to know if to much knock will turn on an ses light cause my long tubes rattle against my k memgers.
Check and clean the terminals on the battery. Also clean all of the connections that are in the little red plastic box on top of the passengers side wheel well. I had the same problem and it turned out that I had a bad connection in that red plastic box. Sorry, I'm not exactly sure what it's called.
squarehead
01-15-2015 07:02 PM
