View Poll Results: How Long???
10min+
7.69%
+6min
19.23%
-5min
12
46.15%
26.92%
Voters: 26. You may not vote on this poll
Warm Up Time
Old Feb 24, 2003 | 08:30 PM
HoneyCombs's Avatar
Warm Up Time
How Long do you warm your Car up in the Morning?
Old Feb 24, 2003 | 08:35 PM
joeSS97's Avatar
5 minutes,unless it is really cold,I will give it 10.In the summer,2-3 minutes usually.Nice car honey.Are you female?
Old Feb 24, 2003 | 08:39 PM
Lost's Avatar
By warm up do you mean sit and idle? Or, do you mean drive easy and not rag on it?
Also, I think your question depends on the ambient temperature a lot. I live in FL and typically I just start it right up and drive off but I don't really get on it for at least 3 to 5 minutes. Now if it were colder I think I might just let it sit till the temps came up to operating temperature.
Old Feb 24, 2003 | 09:45 PM
Terran2k's Avatar
5 mins at most, then i just drive slow for a few then Im set
Old Feb 24, 2003 | 10:25 PM
Mizz96Z28's Avatar
10-15 minutes just idleing since it so cold out here lately.
Old Feb 24, 2003 | 10:39 PM
windnsea00's Avatar
most manufacturers say its better to just turn it on and drive easy till it warms up instead of warming the engine up idiling...if you just sit there warming the engine up, your tranny and rear differental fluids will still be cold...of course i live on the coast so i dont have to worry about too cold of weather either
Old Feb 24, 2003 | 11:10 PM
StreamlineZ28's Avatar
i usually warm mine up for about 5 min utes but i the summer i dont as long but as a rule of thumb i wait at least 30 sec to get the oil pumpin good idont think sitting there letting it idol is any better on the car the driving it easy for a little whilel
i think the worst thing for the car is actually starting it
Old Feb 24, 2003 | 11:38 PM
darkangel95's Avatar
Usually about 5-10 mins, but I always make sure to drive easy for about 3-4 miles also.
Old Feb 25, 2003 | 12:07 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
well in the temperatures we been getting here it would have to idle for 20+ minutes to get up to operating temp. i usually give it a cigarette of time to warm up idleing while im standing in the wind outside freezing my *** off... i'd say about 3 minutes and then i go easy on it fro about 2 miles... i don't like how when the oil is cold the oil pressure jumps to 50 and stays there till 3 miles down the road
Old Feb 25, 2003 | 01:43 PM
96ZRide's Avatar
I drive it easy until the oil pressure gauge dips fairly low at idle, idicating that the oil temp is up to OT.
Then its eligible for a thrashing.
Old Feb 25, 2003 | 02:02 PM
mycarisfasterthanyours's Avatar
I usually just take it easy for a few minutes. Sitting and letting it idle doesn't sound like the best idea to me. At idle, oil pressure is the lowest it can be. I don't know about you guys, but I want to make sure the oil is getting all over everything. If cold oil is harder to pump, and you run your car at the lowest speed, it doesn't seem to me like that is the best strategy. The whole "warming up" thing is pretty much just left over from the carburation days when cars didn't run so well until the manifold heated up.
Old Feb 25, 2003 | 02:08 PM
COMNBYU's Avatar
to be perfectly honset, it depends on whether or not im late for work.
if im late i fire it up and just drive it really easy until operating temp is reached.
my prefference is to give it 5-10 min to wam up regardless of whether its cold or warm outside.
jon
Old Feb 25, 2003 | 02:20 PM
Buttercup's Avatar
jon
FWIW, this is harder on a car. Idling a car to warm it up puts all kinds of contaminents into the oil and puts more wear and tear on the components. Let it idle for 30 seconds and then lightly drive it. Never "hammer" on the car until the oil is up to temp... a good indication of this is when oil pressure drops to normal at idle (for those without an oil temp sensor ).
Idle does nothing to warm up the transmission or rear end either
Old Feb 25, 2003 | 02:21 PM
Brent94Z's Avatar
Super Moderator
Zero warm up time for me. I start it and drive off. Must not hurt too bad because I have no real engine repairs on any of my cars. My 96SS has 97,000 miles on it too and still runs damn good
grgguy
17
Feb 23, 2015 07:57 PM
DetroitZ28
Feb 13, 2015 07:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
Snoman73
Nov 17, 2014 07:22 PM
