Want to rebuld motor for less and stick make 12's
Old Sep 14, 2006 | 03:07 AM
mooner's Avatar
Question Want to rebuld motor for less and stick make 12's
I want to rebuild my 95 LT1 with a goal of beating some newer stock ss camaros (ls1), hope 12s. if i cant reach that with 3000 in the motor which i will do as much possilbe ( take out and install motor myself) the 3000 is all for the parts and labor, where would 3000 get me i know there is other cost like pcm and others ive been though this before just not a rebuild
THANKS
Old Sep 14, 2006 | 03:14 AM
Zeueses 97 RamAir's Avatar
Re: Want to rebuld motor for less and stick make 12's
Call me ill tell what to get and cheap but fast you will be hitting 11s easy with my similar set up on motor....How much you have to spend....
Old Sep 14, 2006 | 03:32 AM
95custom's Avatar
are there alot of miles on the motor? why do you want to rebuild it? for three grand, get exhaust, cam, waterpump, gears, and nitrous. On the street youd be able to beat just about anything with that.
Old Sep 14, 2006 | 01:08 PM
zx1216's Avatar
check out my setup in the sig, might be a bit over 3k but i'm runing 12.4's @114 with stock heads and lower end with damn near 200k. I know i'm pushing it but if you have a 100k car i wouldn't worry at all about camming it. Bolt ons alone should get you close to high 12's and the cam will put you in the mid-low 12's for sure...
Old Sep 14, 2006 | 06:38 PM
96capricemgr's Avatar
To make power it is the heads and cam that need addressing and you can pretty quickly spend the whole $3K on the topend and valvetrain and that is using ported stock heads. Then again it will comfortably exceed your ET goal.
Honestly though if starting with a stock car you will need to spend 3K on supporting stuff before you even think about engine work.
A rebuild without headwork is NOT going to give you much power.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Cam's maro
Dec 29, 2014 08:44 AM
1LEThumper
Jul 14, 2003 12:45 PM
