want to do a cam
Old Mar 21, 2005 | 04:37 PM
steves97z28's Avatar
want to do a cam
this is the parts list so far, correct it if its wrong, cause i really dont know what i need
63-7808-16 Comp Cams Hi-Energy hardened pushrods, 7.200 (OEM Roller - Factory Length) $36.95 $36.95
63-1305-16 Comp Cams Pro-Magnum Non-Self-Aligning Roller Rocker Arms, 7/16" stud, 1.6 Ratio $272.00 $272.00
63-4501-16 Comp Cams "High Energy" Rocker Arm Studs, 7/16" $29.95 $29.95
63-07-306-8 Comp Cams "306" LT1 Camshaft, 230 / 244, .510 / .540 112 LSA $249.99 $249.99 also any other big cams for stock heads(for now) suggestions are appreciated. thanx in advance
Old Mar 21, 2005 | 04:42 PM
Bersaglieri's Avatar
Re: want to do a cam
Combination Motorsports is doing a cam package setup you may want to look into on the Support Vendors area. It would more than likely save you some cash. But it looks like a nice setup. Perhaps some new lifters and dont forget all your gaskets, seals, new timing set, GM guideplates for the NSA rockers, and maybe even an opti or waterpump while its off.
Some other suggestions on a cam - GM 847, XE 223/239, XE 230/236.
-Dustin-
Old Mar 21, 2005 | 05:15 PM
Kataklysm's Avatar
I'd replace the lifters as well. Comp Rs are supposed to be good. Also not a bad time to do the timing chain/sproket since the cover needs to come off.
Old Mar 21, 2005 | 07:09 PM
slp223's Avatar
you are going to need new valve springs. you can use you stock rocker studs and stock pushrods and avoid the guide plates it you get self aligning rockers.
Old Mar 21, 2005 | 07:12 PM
CeeBee94Z's Avatar
Yea you DEFINITELY want to do lifters while you are in there. Same with the valve springs. When I did my cam swap I inspected the stock lifters and decided to leave them in.....well the first time I went to the track, on my second run I collapsed at least two of the lifters (still ran a 13.5 @ 106.xx though) So I had to take it all apart again and put in the Comp R's anyway....
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
