Want to delete A.I.R. have a couple questions
Old Nov 13, 2003 | 09:56 AM
  #16
bradpreece95z28's Avatar
Originally posted by 97WS6SCharged
You will have to have the computer reflashed to get rid of the emissions codes unless you want the service engine light to stay on.
In alot of cases, the obd1 will NOT throw a code....Mine doesnt..
Old Nov 13, 2003 | 10:08 AM
  #17
lbrowne's Avatar
However the OBD2 will.
I want to remove my egr gear but that is whats holding me back.
Old Nov 13, 2003 | 10:14 AM
  #18
formula383's Avatar
Have had mine off the car for over a year now and no SES light, obd1.
Old Nov 13, 2003 | 10:25 AM
  #19
Red96Lt1's Avatar
Are their any drawbacks to taking the EGR system off?
Old Nov 13, 2003 | 08:50 PM
  #20
97WS6SCharged's Avatar
When I put in the 40lb/hr injectors, I converted to OBD1 and had all emissions codes removed just to be sure. The car runs like a dream, although it is a bitch to start sometimes. Oh well.
Old Nov 14, 2003 | 01:23 AM
  #21
Guerardsgt's Avatar
I took mine off because the fuze kept blowing due to moister in the pump. The only real benifits you get from removing this is access in that part of the engine is greatly improved and weight if your big into drag racing. On obd1 you shouldn't trow any codes as long as the fuze remains in the fuze box and is still good. I got rid of all of that tree hugger garbage on my new motor, and it's so much easier to work on now!!!
Old Jan 5, 2004 | 11:20 AM
  #22
Tires_Smokin's Avatar
...so if you take the pump out, will you still pass smog?
Old Jan 5, 2004 | 11:27 AM
  #23
anaik's Avatar
As long as there's no visual inspection. The AIR only operates for a few minutes at start up with a cold engine. It helps to get the cat up to operating temps.
Old Jan 5, 2004 | 12:10 PM
  #24
Maybe I'll leave it out when I finish my opti change. Hmm. As for visual..no prob, I'll just put it back in at smog time. I'll keep searching about this.
DirtyDaveW
Dec 1, 2016 05:37 PM
alex5366
Mar 8, 2015 11:32 AM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
96z
Aug 2, 2002 09:00 PM
