Want 400hp at crank
Old Jan 8, 2008 | 11:04 PM
TBSPW's Avatar
Want 400hp at crank
well i want to make at least 400hp at the crank and need to know the best way to achieve this. At this point i have the mods mentioned in my sig and am soon to add a lt4 hotcam and longtubes and a y-pipe. Also will soon add nitrous with a 100 shot. J/W will i achieve the 400 at the crank without the nitrous or am i still way off.
Old Jan 8, 2008 | 11:07 PM
jpaugh's Avatar
You can do it without nitrous, but more than likely you'll need a set of good flowing heads as well.
Old Jan 9, 2008 | 05:29 AM
rock1501's Avatar
400 at the crank is easy in an LT1.Just get your stock heads ported and maybe a cc306 cam and you are there oh you might need to switch to LT headers and a dyno tune as well
Old Jan 9, 2008 | 06:02 AM
rskrause's Avatar
Moderator
Head porting is needed, along with a cam and headers.
Rich
Old Jan 9, 2008 | 07:40 AM
526 SS 96's Avatar
TBSPW: I used to have the exact set up you are talking about. I made 345 to the tire N/A with a 6-speed (about 407 at the crank, that's adding 18% for drive line loss.) As with anything the tune is critical.
You will get what you want out of that set up, I don't think you will need ported heads.
When I used to have my car set up that way is was a blast to drive. You won't regret it.
Jeff1904
Jun 5, 2016 05:00 PM
Z Power
Sep 19, 2015 11:19 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
