Want to be in 13.0 -13.5 range
Old Jul 11, 2004 | 08:08 PM
  #16
Ekof96Z28's Avatar
My mod list is as follows...
Pacesetter Headers, Cutout after Y-pipe, Custom Exhaust. B&M Trans Cooler, TPIS airfoil, BMR LCA relocation brackets, Autometer A/F and Trans Temp Gauges !CATS, !EGR, !AIR, Descreen MAF, TB Bypass, 160 Degree thermostat, MSD Blaster Coil, PCMforLESS, Lakewood LCAs, Shift kit in fresh rebuilt 4L60E. K&N FIPK
  #17
PredatorZ28's Avatar
there is water that goes threw the throttle body that is hot and hot is no good. U need to disconnect the one side and connect it to the other side.. takes about 20min .. do a search for it or shoebox and then u will see btw my air foil is at 20.00 bucks right now and a new one is 50 buy quick
Old Jul 11, 2004 | 08:24 PM
  #18
n2ceptor's Avatar
For inquiring minds......
http://shbox.com/1/4th_gen_tech1.html
  #19
RedHottG2's Avatar
Just want to clear things up, we didn't hear for sure if you had an auto or 6spd.
Old Jul 11, 2004 | 09:18 PM
  #20
ArrestMeRed's Avatar
Coolent runs through your throttle body. I`m pretty sure it`s so it doesn`t freeze, or somthing. When they say to bypass the throttle body, they mean to by pass the coolent from running through there. I am in NW ohio and have similar winters to you, you`ll be alright if you do this. With what you have listed, you shouldn`t have any problems with getting 13-13.5. I definatly reccomend subframe connectors for that vertable. The higher stall convertor will definatly help, even if it is a driver. My car is a driver and I`m very pleased with the 2400/3.73 combo! I can`t wait till my cam goes in! Also, do you know what ratio gears your car has? If it is an Auto, and has the 3.23`s, then switching to 3.73`s wouldn`t be worth the effort at this point.
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
NewsBot
Sep 14, 2015 02:02 AM
Bails098
Aug 17, 2015 05:15 PM
