HP Guesses!!
Old Jul 11, 2004 | 11:29 AM
c0rey's Avatar
HP Guesses!!
In a week or two im going to take the car into the dyno after i get it all finished and get a dyno tune done. Here are the mods
ATI Procharger D1SC, Dual Intercoolers with 8 psi
Walbro 340 Fuel Pump
Lucas 42.5lb Injectors
Taylor Wires
OTVC Looms
NGK TR6 Plugs
ODB1 PCM4LESS Coversion PCM
LT4 KM
Jet Hot LT's
Hooker Y Pipe
Magnaflow Catback
Granatelli MAF
Throttle Body Bypass
!Air
!EGR
Boxed Subframe connectors
Just wondering what to expect!!
Old Jul 11, 2004 | 12:05 PM
Somnambulist's Avatar
stock top end?
Old Jul 11, 2004 | 01:02 PM
c0rey's Avatar
Yes stock heads/cam/intake
Old Jul 11, 2004 | 01:03 PM
im guessing forged bottom end? what ci? 350?
Old Jul 11, 2004 | 01:47 PM
FastWhiteTA's Avatar
Man if it is tuned properly and has the right fuel system etc, you should be able to hit 400+ rwhp and 450+ rwtq with that procharger. Nice. Let us know what you actually dyno. That must be a tq beast!
Old Jul 11, 2004 | 05:17 PM
Munson's Avatar
hey corey how much did that d-1sc setup cost you?
Old Jul 11, 2004 | 08:06 PM
c0rey's Avatar
The bottom end is stock for now. Until something breaks
4,300 for the kit.
Old Jul 11, 2004 | 09:12 PM
youll bust it quick with 8psi...probably not the best idea man...
it wouldnt even surprise me if you bust on the dyno...
Old Jul 11, 2004 | 09:20 PM
c0rey's Avatar
I have a friend that has ran 9 psi on a 93 TA for 2 yrs with no problems.
Old Jul 11, 2004 | 09:41 PM
HardcoreRM125's Avatar
That thing is going to be disgusting while it lasts. Boost on stock bottoms is a touchy subject. Some last 2 seconds under boost some last 2 years ... Run it till it lets loose, then rebuild as a stroker motor forged with lower comp ratio and run a couple more lbs Goodluck. And for the books, im saying 413RWHP 443RWTQ
brothaslide
Jan 9, 2016 12:11 PM
Greg88
Sep 20, 2015 07:14 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
