Walbro worked for 2 days
Old Apr 18, 2004 | 08:56 AM
chrism400's Avatar
I recently installed the Walbro 255 pump in my LT1. After I had it good to go, I started the car and immediately checked the fuel pressure. It was about 40 lbs with the car running, and about 38 at WOT. I then changed the fuel filter and gained about 2 more lbs. The car was running great for about 2 days and then it started acting like it did with the stock pump that only put out 25 lbs. The new Walbro pump was putting out 12 lbs.
Anybody had a pump go out like this?
Old Apr 18, 2004 | 10:17 AM
Robs97Z28's Avatar
sounds like you have some type of debri in your tank. maybe rust or leftover parts from the first pump. wot fue; pressure should be between 41 to 47 (hose off at idle). at idle vacuum line on 3 to 10 psi drop from first reading with the line off.
Old Apr 18, 2004 | 12:36 PM
blown383's Avatar
Check for junk in the tank or check to see if the fuel line slipped off of the pump......thats what happened to me.
-B
Old Apr 18, 2004 | 09:51 PM
chrism400's Avatar
When the hose slipped off, did you still get a small amount of pressure (I'm getting about 12)? I will definitely check it tomorrow. Thanks.
Old Apr 18, 2004 | 09:58 PM
blown383's Avatar
I believe I still had some pressure because the car would still run but it would sputter and stumble, when I dropped the tank for the third time it was barely on the tube. So I cut off of the snap fitting from the stock pump and used a hose clamp to hook it up to the new fuel line....no more slipping.
-B
Old Apr 19, 2004 | 06:41 AM
chrism400's Avatar
I probably do have the same thing going on. I'm going to check it this morning. Thanks .
Old Apr 19, 2004 | 10:05 AM
chrism400's Avatar
That was it!!!!!!!!!! The hose had come off of the pump and was just sitting on top of it sort of half-cocked. I think this is a good argument for the trap-door method. If anything goes wrong, it's a heck of a lot easier to get to than removing the tank! Thanks B !
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
