Walbro 255 plus an inline booster?
Old Feb 10, 2005 | 07:36 PM
95Zman's Avatar
I have a msd booster pump along with the factory intank pump. The intank pump is weak and not supplying enough volume. The pressure is good im guessing because of the booster. Anyways i have a 255lph high pressure walbro coming. Should i keep the booster pump or remove it? Shouldnt need it i wouldnt think but i also run a dry nitrous kit. any thoughts?
Old Feb 11, 2005 | 03:00 AM
ChevyTuffD.A.'s Avatar
Re: Walbro 255 plus an inline booster?
U dont need it if youve got the Walbro on the way. It should supply all the fuel you'll ever need. Even with the dry shot.
Old Feb 11, 2005 | 08:15 AM
BlownF1's Avatar
Agreed...I'd remove it so that it's one less thing to fail, not a restriction, and won't mask any problems should something go wrong. I'm running a single Walbro 255...removed the T-rex inline pump when the Walbro went on.
Quickss96
Jan 29, 2016 05:56 PM
Boss002
Jan 20, 2016 12:17 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
mrwz28
Jul 8, 2015 09:11 PM
