Which walbro 255, high pressure or low pressure?
Old Oct 20, 2004 | 06:14 PM
stik6shift93's Avatar
I was just about to order this fuel pump from new era and noticed they list a high pressure and a low pressure, which do I need?
Old Oct 20, 2004 | 08:45 PM
1racerdude's Avatar
Re: Which walbro 255, high pressure or low pressure?
Get a Walbro 305. Do it once and forget it.
Old Oct 20, 2004 | 08:52 PM
IrocSS85's Avatar
I have the high press. pump and no AFPR. it works great.
1racerdude, I'll ask for him. where do you get a walbro 305 and how much do they cost? I got my pump from new era cause its cheaper then anywhere else I found it.
chris
Old Oct 20, 2004 | 08:54 PM
tanmanski's Avatar
LOL, I asked that exact same question about 3 weks ago....I was told, go with hi pressure if you think you might ever go with a power adder. For NA, lo press is fine. Are you ordering the wire harness kit too? I havent decided if I'm going with pump only or pump & wire kit. I hear a lot of guys say they have voltage drop over the old harness, but I'm pretty good with wiring & may just re-terminate the existing harness
Old Oct 20, 2004 | 08:56 PM
1racerdude's Avatar
Get it from Racetronics.I got one in my son's car.
At the time it was $106.00.
Old Oct 20, 2004 | 09:28 PM
fbodyfreak's Avatar
http://www.autoperformanceengineering.com/
I got my walbro from them, it was only 97 bucks
Old Oct 20, 2004 | 09:43 PM
1racerdude's Avatar
The pump was a #340(my mistake) and is no longer offered.Walbro makes a pump to replace it though but it isn't a 340.
Old Oct 20, 2004 | 09:50 PM
NoFear95's Avatar
Get the racetronix's kit. Plug and play.
http://www.racetronix.com/Racetronix..._Pump_Kit.html
Got the kit with the wiring kit from Thunder Racing. The BEST intank plug and play set-up you can buy.
HarleyZ28
Oct 5, 2015 06:23 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
Skull Leader
Aug 10, 2002 11:01 AM
snksknr94
Aug 2, 2002 07:31 PM
