Waiting 20 mins to shift in gears(M6)
Old Nov 30, 2002 | 06:44 PM
96Z28TealM6's Avatar
Soon I'll be taking my car to the dealer and try to figure out what the problem is with my shifting. Everyday when I start up the car...I have to wait(up to 20 mins.) until the car is fully heated..almost up to 220 degrees, then I can shift into all of my gears..this is a result of shifting into second while skip shift light was on( happen various times) yes it actually got stuck in second gear, it did not block the shifter like it was suppose. Any suggestions would be helpful
Old Nov 30, 2002 | 08:15 PM
Wild1's Avatar
Bad throw out bearing. Low fluid/damage. Clutch out of adjustment or worn. Just a few thoughts.
Old May 4, 2003 | 01:29 AM
fbird95's Avatar
they use a hydralic clutch, it self adjusts
Old May 4, 2003 | 06:43 AM
joeSS97's Avatar
Have you ever checked the trans oil?Maybe change it.
PCLZ28
Apr 29, 2015 11:56 PM
jb4xx
Feb 2, 2015 10:00 PM
blac94Z
Jan 12, 2015 05:44 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
