Wahts The Story On The Cc 306 Cam...
Old Dec 7, 2005 | 11:12 PM
PROJECT X's Avatar
Hey, everybody was wondering what everyone thought of the 306 cam, is this a good cam, whats it sound like, and would this cam be good on a everyday a4 driving car with a supercharger added to it? everyone-anyone let me know what your ideas and thoughts on this cam are.......any help and thoguhts greatly appreciated
Old Dec 7, 2005 | 11:19 PM
luckyou03's Avatar
Re: Wahts The Story On The Cc 306 Cam...
http://www.lt1engine.com/soundlib/46lt1cc306.wmv
Old Dec 8, 2005 | 04:42 AM
Wckd94Z's Avatar
From what I've heard it's a good choice That's why I'm putting one in my car next week... I'll be posting results in two weeks or so, whenever it gets done!
Uh for you, if you're set on the blower, you'd be better off with a blower grind, or custom grind cam. The CC306 has too much overlap which bleeds off cylinder pressure, though I think you can order a 306 in a 114 LSA which would be better with a blower, but still not ideal. The one I'm putting in my car is a 112 LSA, and I expect a pretty grumpy idle An A4 car needs at least a 2800, preferably 3200 or higher stall and 3.73 gears for this cam to work right. My car's an M6 and I'll be swapping out my 3.42s for 4.11s hopefully for christmas
Old Dec 8, 2005 | 06:05 AM
Jameslt1TA's Avatar
This is probably one of the most talked about cams on here. Search and you will find loads of info on it. That said i agree with what was said above, i wouldn't use it for a blower motor either. I dont like the idea of having cams ground on a diff lsa to tame it down or whatever either it doesn't seem to work to well.
Old Dec 8, 2005 | 10:04 PM
PROJECT X's Avatar
ok im gonna rack your brains what would be a good ideal cam for a blower setup on my car then by the way thanks for the info so far
Old Dec 8, 2005 | 10:18 PM
MEAN LT1's Avatar
The FI forum would be a goos place to start. By far the most popular blower grind has to be the 224/236-114lsa.
Old Dec 9, 2005 | 01:10 AM
DarkDemon's Avatar
Originally Posted by Wckd94Z
From what I've heard it's a good choice An A4 car needs at least a 2800, preferably 3200 or higher stall and 3.73 gears for this cam to work right. My car's an M6 and I'll be swapping out my 3.42s for 4.11s hopefully for christmas
is that true? i'm switching to a3600 stall in the future (has a 3200 right now) but i figured i'd be alright with the 3.42s
Old Dec 9, 2005 | 04:07 AM
30696bird's Avatar
I had 3.73 gears untill I went to the track and broke 7 teeth off the ring gear. After I broke the gears I bought a rear with 3.42's and I LOVE the 3.42's when I build my new rear after the first of the year (9") I will be putting the closest gear to 3.42 I can find in it (I think it's 3.50) I like the 3.42's better. It just depends what you wanna do with the car and how fast you want to be going when you wind them out.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
NewsBot
Sep 16, 2015 10:30 AM
NewsBot
Sep 14, 2015 08:50 AM
