how hard is it to LT's on my 97 WS6?
Old Dec 8, 2005 | 04:23 PM
FNKWICKZ-28's Avatar
I want some pacesetter long tube headers for my 97 ws6, how hard is it to put on, can i go from the bottom and sneak them through, or is there alot of time and effort to get these things on.
thanks dave,
Old Dec 8, 2005 | 04:27 PM
lt1street's Avatar
Re: how hard is it to LT's on my 97 WS6?
Simple job i did in my pit at my shop, two hrs to get them in, I had more trouble with the y-pipe, if you can get under the car you have it made man
UtOhCop's Avatar
thanks dave,
It's more of a bitch getting the stock manifolds off then putting headers on.
Old Dec 8, 2005 | 05:03 PM
Evil Eric's Avatar
Yeah, getting the manifolds stock Y-pipe off is the hard part. I cut my y-pipe off with a saw-zall so that the manifilds would come out the bottom easy. Im to lazy to use wd-40 and socket extensions.
Old Dec 8, 2005 | 05:17 PM
pHEnomIC's Avatar
That's the way i do it, very smart idea since, you know for sure, you aren't gonna be putting them back on.
I've looked over the install guides and it seems that once you get everything out, just gotta wiggle everything in there and bolt it in.
Old Dec 8, 2005 | 11:35 PM
2000GTP's Avatar
Drivers side headers went in from the bottom, the passenger side from the top. Make sure you mask the headers or wrap up the sharp spots in the engine bay so you don't scratch the headers trying to wrestle them in. I also used a sawzall in several places, it made disassembly alot quicker. Also, spray all the old manifold bolts real good with PB Blaster or equivalent before you start to break them free.
Old Dec 9, 2005 | 08:46 AM
Eddie Z-28's Avatar
When I did mine, I did mine very sequencially. The first night we worked on it, we took everything out that needed to be taken out before actually getting down to business. Once that was done, we nailed the stock header bolts with WD 40 and let it sit over night, then went down the next morning and hit them again just for good measures. That evening when we got back to work, I went under there with an air ratchet and they came out like butter.
But don't get me wrong, it's still a pain in the ***.
Stephen68
Oct 16, 2015 03:50 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
