VS739R stock replacement spring?
Old Mar 13, 2011 | 05:31 PM
FratmanZ28's Avatar
I went to the auto store today and got "Stock" replacement springs, my dumb move was I didn't look at them till I got home and noticed they were a dual spring and after googling I learned they are a little bigger than stock lt1 springs. Are these ok to use on stock application? If they are what valve spring retainers would I use now?
Old Mar 15, 2011 | 07:58 AM
FratmanZ28's Avatar
Re: VS739R stock replacement spring?
Old Mar 15, 2011 | 04:36 PM
n2ceptor's Avatar
NOTE: 10206040 (Discontinued)
This single valve spring is use on LT1/LT4 pre-1995 Production Corvettes.
Technical Notes: Single spring with 1.30" O.D. and 1.26" solid height. The pressure at installed height is 85# @ 1.78" with 373# the average rate of pounds per inch.
ZVS739R
Outside Diameter of Outer Spring (in) 1.264 in.
Coil Bind Height (in) 1.160 in.
Damper Spring Included Yes
Inside Diameter of Outer Spring (in) 0.880 in.
Installed Height (in) 1.700 in.
Seat Pressure at Installed Height (lbs) 104 lbs.
Open Height (in) 1.210 in.
Open Pressure (lbs) 277 lbs.
---Unless I have the wrong intell, its alittle smaller outside dia.... And not as strong????
Old Mar 16, 2011 | 08:51 AM
FratmanZ28's Avatar
They're speed pro springs, is this still good with stock valve train? It's a 94 Camaro that its going into.
Old Mar 20, 2011 | 06:37 PM
FratmanZ28's Avatar
If I can use them I'll use them, but if I can't I kind of need to return them before the 30 days is up. Anybody know if these work on stock cam/rocker/pushrod set up?
Old Mar 20, 2011 | 07:35 PM
Bersaglieri's Avatar
Is it a dual spring or has a damper inside? Picture would help, but to be honest your probably better off upgrading to a LT4 spring setup or some Isky 235D's or something to that effect.
Does the stock hardware look like it will fit with no issues? Maybe take the stock stuff off one valve and get us some side by side pictures.
-Dustin-
Old Mar 20, 2011 | 09:53 PM
FratmanZ28's Avatar
http://www.northernautoparts.com/Pro...ctModelId=2297
Old Mar 24, 2011 | 01:32 PM
FratmanZ28's Avatar
Old Mar 24, 2011 | 01:48 PM
If you want help you should probably show us what your working with, as I already asked. A link with a generic picture with zero words from you simply isn't going to cut it. Measurements on the internet isn't half as good as you measuring it in person and proving/showing what the problem is.
You want to know if they are bigger take a caliper and measure the ID and OD. You think they are dual springs take a picture so we can see if it's just a damper. Wonder if the stock retainers will work, take a picture of the retainer on a stock spring vs the speed pro spring.
You need to answer what I asked last time for anyone to help you. You didn't answer a single question or provide a lick of first hand info.
-Dustin-
-Dustin-
Cam's maro
Dec 28, 2014 09:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
GigaMp3z
Feb 20, 2003 02:57 PM
mjcent922
Jul 27, 2002 12:42 PM
