Which VP race fuel to use for when I race (with N20)
Old Sep 7, 2004 | 03:03 PM
JeremyKweens's Avatar
Im looking for a race gas for my Z to use on the juice. I should probably use an unleaded fuel............would VP's motorsports 103 be a good choice??
any other suggestions?
Old Sep 7, 2004 | 07:09 PM
12SCNDZ's Avatar
Re: Which VP race fuel to use for when I race (with N20)
Motorsport 109 is the highest octane VP sells. It has a 101 "motor octane"
Motorsport 103 has a 99 "motor octane".
BTW, your oxygen sensors won't like you anymore if you try to use leaded fuel.
Frank
Old Sep 7, 2004 | 07:47 PM
944v8inDFW's Avatar
I personally use the VP 103 with N20 and no problems on or off the bottle. Otherwise i use 91 pump gas for day to day driving
Old Sep 7, 2004 | 07:56 PM
rpm4lalo's Avatar
Do you have something to monitor knock???, even with a 113 trap speed you still might not need race gas.
Old Sep 7, 2004 | 07:57 PM
I will be running a 150 shot tho.......so race gas is a must.
for just the 100 shot I run 92 octane and thats it
Old Sep 7, 2004 | 08:05 PM
rpm4lalo's Avatar
Not a must, but defintelty safer if you don't have something to monitor knock retard and don't have a way to reatrd the timing. I am running a 140 shot on top of a heads and cam combo that makes 397rwhp NA it's tuned to run on 93 octane on the bottle. Do you have a scanmaster? Or perhaps something like PCM Comm to monitor knock retard?
Old Sep 7, 2004 | 09:00 PM
LameRandomName's Avatar
You know; 2 gallons of Toluene and 4 gallons of 93 Octane gives you 100 octane at about $3.00 - 3.50 per gallon, depending on your local prices for the two ingredients.
Theoretically, you could run straight Toluene, which is a pure hydrocarbon (Or so say the chemists... how the hell should I know?), but at 114 Octane, unless you had a very high compression and a strong ignition system, you might have trouble lighting it.
There was some kind of race car.... I think F1, but I don't really remember. They used straight Toluene, and added back in some other chemical that had a zero ocatane, just to bring it down to rules specs.
Old Sep 7, 2004 | 09:56 PM
where can I get Toluene from??
Old Sep 7, 2004 | 10:15 PM
zx1216's Avatar
you can get it from most bigger paint shops, i think the home depot had it but i mey be wrong.
Old Sep 7, 2004 | 10:29 PM
I just picked up 6 gallons at Sherwin-Williams. They actually do quite a business in it, at least this store does. They can for damn sure get it.
The product numbers are:
1 gallon = 154-8668
5 gallon = 154-2372
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
mark0006
Mar 21, 2015 12:32 AM
T/A lt1
Oct 10, 2002 03:14 PM
T/A lt1
Sep 5, 2002 06:53 PM
