Voltage issues
Voltage issues
Is it normal for the voltage to vary while driving at a constant speed or while sitting at idle? I had my scan tool hooked up and the voltage varied between 11.5V and 13.8V at idle, and while driving down the hwy at 65mph, the voltage would vary between 12.7V-13.6V. In both cases, the readings were erratic--it never stayed too long at one end or in the middle, it was just all over the place. Any ideas?
time for a new alternator bud, mine did the exact same thing LOL. I tried changing the brushes & even tightening the back contact up with no success, either a phase is on its way out or a short in the stator winding or something.
Hope this helps, Matt.
Gtpguy
Jan 26, 2015 04:50 PM
Also get a load test for the battery, too... It will give you an idea if your cells are weakening....
