voltage at idle
Old Aug 30, 2017 | 01:03 PM
frankrizz's Avatar
voltage at idle
Hey Guys,
Getting different voltage readings at idle.
Autometer dash gauge reads 12.3
When I run a scan it fluctuates between 10.7 and 11.9
When I put a volt meter directly to the battery terminals it reads 14.6
Which reading is accurate? Car seems to turn over a bit sluggish sometimes.
The battery and all ignition components are all new. Any suggestions?
Old Aug 30, 2017 | 01:14 PM
97rebuiltZ28's Avatar
Re: voltage at idle
Mine does the same thing where it turns over sluggish sometimes when warm even though I just did a complete rebuild with lots of new parts including the battery.
Old Aug 30, 2017 | 03:12 PM
Re: voltage at idle
Battery will normally read the highest.
Scanner shows you the voltage at the PCM. There's voltage loss through (factory circuit described, yours will be different) red junction box, fusible link E, splice S200, ignition switch, connector C200, fuse #5, connector C230, a splice that splits the wiring to PCM pins B30 and D3, and the MAF sensor, and all the intervening wiring. Ground is supplied from G102 (stud at ICM/coil brcket) and G103 (on block above starter) I would take a good look at the PCM 12 volt wiring, and the grounds. 10.7 volts at idle is too low. You should see 12-13 volts at the PCM at idle, based on the 100's of data logs from healthy engines that I have looked at. An underdrive crank or alternator pulley can be a problem as well, depending on engine idle speed.
Gauge depends where you attached the wiring.
