Voltage drops...
Old May 20, 2007 | 11:41 AM
'94 Bad A Z28's Avatar
Voltage drops...
... to about 10volts under hard acceleration. When you get out of the throttle it goes back up to ~13volts. Anyone ever experience this? Anyone know what this could be?
Old May 20, 2007 | 01:48 PM
2000GTP's Avatar
I would probably confirm that you have clean, tight connections with the battery and the power and ground terminals on the passenger shock tower.
Old May 20, 2007 | 02:32 PM
Dave89IROC's Avatar
if these are good, sounds like the alt has low output at high rpm
Old May 20, 2007 | 04:12 PM
chevyinside's Avatar
belt tensioner going bad , belt slip
Old May 20, 2007 | 04:14 PM
I think so far I am going with low out put at high RPM, the altinator is prolly starting to go. :/
Old May 20, 2007 | 04:49 PM
aboatguy's Avatar
Before you buy a replacement alternator, I suggest that you take it to Advance Auto or Autozone for an alternator testing. That way you don't throw parts at it.
Mike
Old May 20, 2007 | 05:31 PM
I did and it was like .5 volts low or something stupid like that. Which is I why I said it's prolly on it's way out.
Old May 20, 2007 | 07:07 PM
dangalla's Avatar
would low output really cause it to drop that low(10v), wouldnt it drop to somewhere around 12
Old May 20, 2007 | 07:21 PM
still say it sounds like a slipping belt
Old May 20, 2007 | 09:04 PM
Dave89IROC's Avatar
thats a possiblity
Old May 21, 2007 | 12:53 AM
The belt is only about a week old.
Old May 21, 2007 | 01:09 PM
LiENUS's Avatar
Was the tensioner changed with the belt?
Old May 21, 2007 | 02:35 PM
Wild1's Avatar
My bet is on the tensioner.
Do you have a voltmeter?
Engine running tests:
Set your voltmeter (DVOM) to Volts DC. Put one terminal on the negative battery clamp and the other somewhere on the block... you should have 0V.
Put the DVOM on the positive clamp and on the hot lead coming out of the alternator... you should have 0V.
Put the DVOM on the negative clamp and on the hot lead from the alternator... you should have over 13V
There is a possibility you may have resistance in one of your connections, cables, etc. But, with RPMs and voltage dropping, it could be that the alternator is slipping... check the tensioner. Especially if it is a high-mileage engine.
RUENUF
Mar 13, 2016 03:37 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
Aug 7, 2015 01:26 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
