voltage drop
Old Jun 21, 2016 | 01:43 PM
frankrizz's Avatar
voltage drop
hey members, I had a bad miss at high rpm between 2nd and 3rd gear.
Tranny checked out ok at a reputable shop. Tech noticed a voltage drop from 13.6 volts to 11.6 with all accessories on including a/c. The miss sounds like a stumble, then smoothes out when I let off the gas. Code 50 came up on scan. Any thoughts?
Old Jun 21, 2016 | 02:15 PM
Chimera96's Avatar
Re: voltage drop
code 50 would be system voltage low
at 11.6 vdc sounds like the voltage regulator inside the alternator (assuming you are using the donor car alt) is bad. You can buy parts and replace or just get a new alt
low voltage will make computer controlled cars have all kinds of issues...like miss/stumble
Typically high RPM stumble/misfire is a failing Optispark
given your low output voltage....you need to correct that and ideally the stumble will go away
Alt should be putting out about 14.6 vdc to the battery.
Old Jun 26, 2016 | 12:11 AM
RobbyRob's Avatar
Re: voltage drop
I had the same problem and I rebuilt my alternator to a 200 amp and did a direct power to the fuel pump and up graded battery cables. Reduced the voltage drops big time.
Old Jun 27, 2016 | 06:16 AM
plattted's Avatar
Re: voltage drop
What steps did you take to upgrade the Alt to 200 amps?
Old Jun 27, 2016 | 10:04 AM
Chimera96's Avatar
Re: voltage drop
Having a quality set of battery cables helps reduce/eliminate voltage drop. I got cables from this place. Gary makes great stuff
Camaro | Innovative Wiring LLC
200 amp kits to rebuild the alt are available online if you feel you need it. IMHO those are for the big stereo amp guys. I just replaced brushes in mine. There are "how to " videos online so rebuilding the alt is not hard.
Old Jun 27, 2016 | 10:14 AM
Re: voltage drop
Agreed - stock engines, and even heavily modified engines (I run two fuel pumps, huge low impedance injectors, two ECU's, bottle heaters, heavy instrumentation, etc.) seem to have no problem surviving with the stock 140-amp alternator.
Wolf95
Jan 23, 2024 09:21 AM
Stephen68
13
Mar 2, 2017 04:33 PM
Brett Murphy
Jun 18, 2016 10:19 PM
edman
Apr 28, 2016 10:09 PM
leon96z
Mar 26, 2016 03:16 PM
