violant vibration between 1500 and 1000 rpm
Old Oct 29, 2010 | 11:26 AM
edubon97z's Avatar
Hey guys I need help my car is shaking violently between 1500 to 1000 rpm whether standing still or driving or other rpm ranges seem to be normal vibration. everything seems to checkout ok and there are no codes. i did notice the low oil light on dash come on from time to time. but i do not know if it is actuate because my oil pressure sensor is not connected so gauge not working. The car has clean oil and filter. the tuneup was done. Any suggestions before I take it to the shop.
Old Oct 30, 2010 | 06:33 AM
The low oil light has nothing to do with the oil pressure sensor. Its a level switch in the oil pan. Might be telling you something. Also might be a good idea to hook up your oil pressure sensor.
Since you indicated the RPM range is "1500 to 1000rpm", are you indicating that this problem occurs when the engine is decellerating? May indicate the oil pump pickup has fallen off, and you are losing oil pressure on decel.
Xiantyl
Jul 21, 2015 05:42 AM
GT what?
Jul 14, 2015 10:17 PM
birdblack
Jul 8, 2015 07:23 AM
colts0455
Jul 8, 2015 12:21 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
