(Video INSIDE)
Old May 22, 2003 | 03:01 AM
96redformula7's Avatar
Angry (Video INSIDE)
I have been eharing a niose lately whether it was their or not I do not know. Well, The noise seems to be coming from the driver's side by the manifolds. Check it out and let me know what you think it could be. Thanks all
http://www.angelfire.com/alt/96redformulaguy/mycar.wmv
Old May 22, 2003 | 09:49 AM
hairbear21's Avatar
Check for a cracked or leaking exhaust manifold, and you can put your hand over the EGR valve, because I can hear that making some noise as well.
Old May 22, 2003 | 10:00 AM
quicksilver97ta's Avatar
Its difficlut to tell from the sound clip but it prolly either andexhaust leak like hairb said or a problem with the valvetrain creating noise. Try a stethascope to narrow it down. BTW I couldnt see the video, only the sound clip.
Old May 22, 2003 | 11:20 AM
I have got everything from normal injector noise to valve train. The car is not throwing any codes.
Old May 22, 2003 | 11:30 AM
xxsaint69x's Avatar
sounds like exhaust leak/Lose Rocker.
Old May 22, 2003 | 11:37 AM
Sounds like valvetrain noise to me.
Old May 22, 2003 | 12:13 PM
I don't know if you all turned up your speakers, but it is the high pitched tapping noise, it seems to accelerate with the engine being revved.
Old May 22, 2003 | 12:58 PM
xxsaint69x's Avatar
take the valve cover off...
Old May 22, 2003 | 01:06 PM
SloMofo's Avatar
Link did not work for me
Old May 22, 2003 | 01:07 PM
Purple Meanie's Avatar
my car is making the exact same noise.
adjusted the rockers several times with no luck.
ditto with the egr.
found one injector that was questionable.
it seems the noise dies down after driving around for 15 - 20 minutes but doesn't completely go away.
maybe some sticky lifters?
Old May 22, 2003 | 11:40 PM
Laymaster's Avatar
you got owned by angelfire..shut down for excessive bandwidth.
it told me to try back at 3am.
Old May 23, 2003 | 04:09 PM
Tires_Smokin's Avatar
I agree with Shoebox...my car makes the same noise and my car has been baby'd to death. It's too soft of a noise to be a knock or ping. I believe its just valvetrain noise.
my 02cents
HAWG
Sep 25, 2015 11:41 AM
cmsmith
Sep 14, 2015 09:09 PM
mark0006
Sep 14, 2015 12:35 PM
Daluchman1974
Sep 11, 2015 06:12 AM
