vibration at speeds 90 and above
Old Jun 4, 2003 | 02:28 PM
Metlhed54's Avatar
when i hit 90 my car starts to shake a lot in the back and i dont know what it could be its only at that speed and higher, any suggestions would be appreciated. THanks dan. it soudns like it could be tire related like out of balance is that a possibility?
Old Jun 4, 2003 | 02:31 PM
madwolf's Avatar
Most likely your driveshaft. Is the vibration pretty violent or not too bad? Does it disappear later on or it only gets worse as the speed increases?
Old Jun 4, 2003 | 02:32 PM
RobK's Avatar
Sounds like a driveshaft balance problem similar to what I had. I have since switched to an LS1 aluminum one and my problem went away.
Old Jun 4, 2003 | 02:54 PM
96 TA's Avatar
I know that when my tires were mis aligned that I got a vibration at higher speeds. Try getting them balanced and see if it goes away. But it might as well be a balancing issue with the DS.
Old Jun 4, 2003 | 11:59 PM
Metlhed54's Avatar
yeha i was thinking either of those two i think i will call and go get my tires balanced and hopefully tahts all it is
Old Jun 5, 2003 | 12:03 AM
Jcb890's Avatar
If it does happen to be an unbalanced DS, as i have this same scenario, is there nething that can b harmed or nething bad going to happen because of it?
jake
Old Jun 5, 2003 | 01:04 AM
csabatka1's Avatar
Assuming you've got a stock driveshaft, that is more than likely you're problem. The stock steel 93-97 driveshaft is notorious for these types of vibration problems, mainly over 80 + mph.
Other suspect part may be ujoints.
Old Jun 5, 2003 | 01:13 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
balance tires/wheels.... obviously...
or get an ls1 driveshaft
Old Jun 5, 2003 | 02:48 AM
Dmx4ever3's Avatar
Angry ??
I GOT AN LS1 DS OUT A 99 SS AND MY TIRE BALANCED AND I STILL HAVE THE SAME PROBLEM BUT NOT AS BAD AS BE4 , AND THE OLD DS THE U JOINTS WERE BAD
WHAT CAN MY PROBLEM BE???
Old Jun 5, 2003 | 02:51 AM
frmula1's Avatar
bad roads?
a tight, sports car suspension, hemroids?????
Old Jun 5, 2003 | 02:57 AM
Dmx4ever3's Avatar
IF I PULL IT OUT OF GEAR ITS SMOOTH FOR THE MOST PART?? AT ANY SPEED
Old Jun 5, 2003 | 02:59 AM
mastrdrver's Avatar
I have the same problem starts at 80mphand goes away after about 105mph. The dealer told me it was my Baer brakes. It only started after they rebuilt my tranny. Anyone have an idea?
Old Jun 5, 2003 | 03:18 AM
frmula1's Avatar
could simply be the dirometer in the tranny mount....
which mounts you usen?
AND STOP USING CAPS
Old Jun 5, 2003 | 03:24 AM
Dmx4ever3's Avatar
i have a poly tranny mount
Old Jun 5, 2003 | 03:26 AM
frmula1's Avatar
well there you go...
the dirometer on polyurethane is high... (that means the mounting material, is harder) therefore they transfer more vibes...
its a common problem...
