Vibration Problem
Old Jul 16, 2009 | 10:06 PM
mcflyiup's Avatar
Vibration Problem
I have a Vibration from about 3k - redline, while in Nuetral. Doesn't matter if I'm reving or holding a steady rpm. The motors internals are completely stock and the car has about 38k miles. I recently put a Mcleod Twin Disk Clutch in and had it matched balance to the factory flywheel. It was off by only 14 grams, so no big deal. I have new poly mounts for the engine and trans. I had a water pump leak, which I replaced but I know the opti got soaked with coolant for a little while. It doesn't feel like a miss.
Could it be the opti? I need some options because its pretty bad!
What steps can I take to narrow down the problem?
Old Jul 17, 2009 | 03:54 PM
SnakeOiler's Avatar
did the vibration start when you added the poly mounts? more than likely that is your cause.
Old Jul 17, 2009 | 04:26 PM
rclearyiii's Avatar
Flywheel
I had the same exact is on my 96 M6. Had to change the flywheel twice to finally cure the issue. Just a thought. The lt1 is externally balanced and any deviation can cause vibrations.
Old Jul 17, 2009 | 07:08 PM
Wild1's Avatar
The rotating assembly and the balancer are internally balanced. The flywheel is externally balanced. It's pretty much what you said but I wanted to clarify.
I have a 3K - 6K vibration too and just changed the to poly mounts. But, I've got a lifter not pumping which is causing a severe vibration.
Old Jul 17, 2009 | 07:24 PM
rclearyiii's Avatar
Balance
Actually..unless you have changed the rotating assembly...it is not internally balanced but externally balanced by the flywheel on a lt1.
Old Jul 17, 2009 | 07:47 PM
Wild1's Avatar
I had a Centerforce Flywheel bolted up to the stock rotating assembly. The aftermarket flywheel was neutral balanced. If the rotating assembly was externally balanced to the flywheel, then wouldn't I have noticed a vibration?
Old Jul 17, 2009 | 07:53 PM
rclearyiii's Avatar
Balance
Yes..if you had a neutral balance flywheel on a lt1 you most certainly should have noticed vibrations if indeed the aftermarket one was neutral balanced. Are you sure that it was not made for a stock lt1 and balanced or it?
Old Jul 19, 2009 | 11:16 AM
mcflyiup's Avatar
I had the vibration before the poly mounts and thought the stock were shot, so I switched. I had flywheel matched balance to the stock flywheel, which is the recommended procedure. I'm gong to look at the harmonic balancer today and do a compression test. I may pull the valve cover to look for a broken valve spring or a bad lifter. I would hope the flywheel isn't still the cause but you never know!
Old Jul 19, 2009 | 04:12 PM
rclearyiii's Avatar
Balance
Good luck on that. I finally just broke down and bought a new flywheel from gm and it solved my problems. I think I could change those things in my sleep now..lol.
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
Rde Bandit
Mar 21, 2015 10:17 PM
karnykamaro
Feb 2, 2015 01:37 PM
mattszm6
Dec 14, 2014 07:09 AM
