Curb Idle Speed
Old Jul 19, 2009 | 03:56 PM
canuck94z28's Avatar
Question Curb Idle Speed
My curb idle speed is about 550-575 rpm on my 94Z28.Due to my March U.D&Vig.stall this is much too low(battery/alt. charging issues)etc.Car feels sluggish around town.I need to raise idle to about 675-700rpm;i,ve raised it to 600-625 via the screw on the factory t.b but still needs more.Can this idle be raised more by that screw or get my tuner to do it?Thanks.BTW this is more evident since i had the Vig.stall put in!
Old Jul 19, 2009 | 04:10 PM
The idle is controlled by the computer. Even if you change the screw on the TB (which you should not mess with), the computer will still try to keep it at the same RPM. Messing with the throttle stop screw will throw your TPS and IAC readings out of whack and you will end up with more troubles. You need reprogramming to change the idle speed.
Old Jul 19, 2009 | 04:56 PM
Update
Yes i noticed that the tps volt on my scanmaster was now @0.78 vs. the 0.70 it was b/f.I will send my pcm to madtunerz28 to raise idle to 675-700 rpm&do some other updates @the same time.Btw i will get my local mechanic to set the screw back to the orig.position.Thanks shoebox for that reply.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
edman
Mar 13, 2015 09:39 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
edman
Jan 25, 2015 02:41 PM
