vibration
Old Sep 16, 2007 | 03:58 PM
quiksilver2871's Avatar
vibration
alright im getting a really weird vibration in my car. it only happens when the car is under a load and usually in second gear or higher. when i had my motor rebuilt the builder found a shattered pilot bearing and replaced it. i thought that was the problem before but it was back. it doesnt happen all the time. i can put it under the same conditions multiple times and it sometimes doesnt do it, but it mostly does. i can feel it heavily in the shifter. i thought it might be a ds or the rearend, but would it go away when i put the clutch in? also could the computer think its knock and retard timing?
Old Sep 16, 2007 | 07:22 PM
95Blackhawk's Avatar
Need to read your computer to find out about the knock.
How about an unbalanced pressure plate? vibration goes away when you put in clutch? please explain.
Old Sep 17, 2007 | 12:35 AM
well like i can find the point where it vibrates and then once i press the clutch pedal, the vibration stops. it seems like it does it around 3k
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Apr 16, 2015 09:57 AM
